Activity › Forums › Apple Final Cut Pro Legacy › Faster Drives
Faster Drives
Posted by Dan Browne on January 11, 2011 at 9:19 pmWe have recently started capturing from tape uncompressed footage as opposed to the FCP codec, because we were getting too much artefacting after grading.
But one new problem that has started to happen, is while capturing, FCP will crash out quite a bit. I’m thinking this is because the data rate of the footage coming in is faster than the speed the drives are able to write at. I have noticed every now and again it says that its maybe a few seconds behind real-time capture… And its usually when this spans for too long that it crashes.
So wanting to know, what would be a faster drive solution. Currently I have Sata2 internal drives which we are using… But is there an external drive solution? Maybe one where you can buy some kinda PCI-E interface type card or something to attach to the enclosure? And not too overpriced… So maybe a few grand is okay, but nothing like 10 grand or anything…
Dan Browne
Hawkes Bay, New Zealand
http://www.indelible.co.nzThomas Morter-laing replied 15 years, 8 months ago 4 Members · 10 Replies -
Shane Ross
January 11, 2011 at 9:27 pm[Dan Browne] “We have recently started capturing from tape uncompressed footage as opposed to the FCP codec, because we were getting too much artefacting after grading.”
Which codec? ProRes? I’ll guarantee that the artifacting that is happening, showing up, is due to your source material. What is that by the way?
To capture UNCOMPRESSED you need a good 5-8 drive mini-SAS raid. MaxxDigital EVO2 line, Caldigit HD One for example. But why not capture a small bit that you can capture now, run a correction test and see if the artifacting is better? If so, then there you go.
Personally I haven’t heard of artifacting issues with ProRes…I I have done a lot of it, and know many many other post facilities that deal with it. But, do what works for you.
Shane
Read my blog, Little Frog in High Def -
Thomas Morter-laing
January 11, 2011 at 9:29 pmWhat are the specs of the rest of your computer? Are we talking HDV footage? What do you mean my “FCP Codec?”
I’d be surprised if it was the drive speed, I’ve successfully captured onto a 5400rpm external FireWire 400 drive before (although I was concerned so admittedly sat there for 6 hours watching it)- What’s your capture device?
Tom Morter-Laing
Freelance Editor
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.ukSony Z5, with Rode NTG2.
iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD. -
Thomas Morter-laing
January 11, 2011 at 9:32 pm(Sorry Shane, looks like I replied as you were- I only asked about uncompressed because some people assume when it doesn’t transcode on capture that means it’s uncompressed…. Rather than uncompressed HDV)
Tom Morter-Laing
Freelance Editor
Dan Browne
January 11, 2011 at 9:42 pmNa sorry, got that wrong. We were capturing HDV with the FCP default codec… but now proress 422 (HQ). The artifacting was with the HDV. Not really that visible in the original footage, but you could really tell it with the graded stuff. And we did side by side tests and you can tell a difference in quality.
Dan Browne
http://www.indelible.co.nz -
Shane Ross
January 11, 2011 at 9:46 pmYeah, your issue is with HDV. Capturing it to ProRes, to Uncompressed…won’t fix the horrid HDV codec. It is a complete pain to color correct. I did that for over a year and cringed on each and every episode I had to do.
HDV sucks…pure and simple.
Shane
Thomas Morter-laing
January 11, 2011 at 9:46 pmDan, tip for the future, Apple Prores HQ is a waste of space and processor power with HDV. Use standard pro res or even prores LT and it’ll be fine, and save you a LOT of hard drive space as well.
Tom Morter-Laing
Freelance Editor
Dan Browne
January 11, 2011 at 9:48 pmYeah, capture pre-set just HDV…
The computer is MacPro 2xQuad Core Intel 3ghz. 4gb of ram…
Dan Browne
Dan Browne
January 11, 2011 at 9:58 pm -
Walter Biscardi
January 12, 2011 at 1:36 am[Shane Ross] “HDV sucks…pure and simple.”
Yep, you can try to dress it all as much as possible, capture uncompressed, heck capture 4:4:4 if you want, but it’s still crappy HDV underneath.
This really requires a LOT of work in color correction. At least with Apple Color you can really target the excessive noise in the individual color channels. This helps out a lot to mask the noise.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
Thomas Morter-laing
January 12, 2011 at 10:01 amI love how so many threads turn unto a hate chain about HDV…. I happen to have a Sony Z5 and I find it all so hurtful :’S
(Joking)
Tom Morter-Laing
Freelance Editor
