Activity Forums Apple Final Cut Pro Legacy Fast movement and “lines jiggles”
  • Fast movement and “lines jiggles”
    Posted by Agust Gudbjornsson on February 17, 2009 at 3:36 pm
    I know this is common problem, especially for newbies in the video production area. I would like to know if this is happening hardware wise and with the software (Final Cut Pro latest).
    The basic problem is that in fast movements I get those jiggle lines in the parts of the moving objects.
    Preview:
    https://macthinker.com/lines.png
    Does anyone have a solution and explanation for this to help me out.
    Agust Gudbjornsson
    Agust Gudbjornsson replied 17 years, 7 months ago 2 Members · 2 Replies
  • Peter Wiggins
    February 17, 2009 at 3:39 pm
    That is interlacing and is completely normal.
    Use a deinterlace filter if you want to remove them, but you will lose half your vertical resolution.
    Peter
  • Agust Gudbjornsson
    February 17, 2009 at 4:28 pm
    Thanks allot for fast response, I´ll read about it on wiki ,o)
