Activity Forums Apple Final Cut Pro Legacy Fast connection to an ESATA
  • Fast connection to an ESATA
    Posted by Steve Cohen on April 9, 2008 at 12:55 am
    A while back I saw a post about temporarily connecting a SATA drive so you can write something to it quickly or read something from it.
    There were a couple of options ranging from a thing that looked like an Ipod player the you dropped the drive into to a cable that you hooked up and then plugged into the Mac.
    What I’m looking to do is take a spare drive,clone my startup drive and then put the spare one on the shelf, but I don’t want to open the case every-time I want to run a backup and I don’t want to put the drive in an external case, because if my system drive fails I just want to throw it in and get back to working.
    Anyone have any idea of the items I’m speaking of???
    Steve Cohen
    Editor
    O2 Media Inc.
    David Roth weiss replied 18 years, 5 months ago 5 Members · 4 Replies
  • Jerry Hofmann
    April 9, 2008 at 1:04 am
    Actually, there’s a unit made by Wiebetech that would do the trick:
    https://www.wiebetech.com/products/ComboDock.php#pricingavailability
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mitch Sink
    April 9, 2008 at 1:43 am
    [Steve C] “What I’m looking to do is take a spare drive,clone my startup drive and then put the spare one on the shelf, but I don’t want to open the case every-time I want to run a backup and I don’t want to put the drive in an external case, because if my system drive fails I just want to throw it in and get back to working.”
    These Exteral Cases by Weibetech use a bare drive so you can use it just as conveniently as a bare drive but it will be more protected in the case:
    https://www.wiebetech.com/products/RTX100.php
    Overview of RTX 100 Series
    Each have 1 bay, accept SATA drives, and include RTX TrayFree™ trayless bays – no screws, no trays.
    If you are running Leopard think a better idea would be to partition the drive and use one partition for a periodic clone and use the other for Time Machine backups and leave it connected or disconnect it periodically (when doing captures for example).
    Best Wishes,
    Mitch
  • Sean Oneil
    April 9, 2008 at 1:45 am
    This thing here is expensive but could be nice to have:
    https://www.geekstuff4u.com/product_info.php?manufacturers_id=&products_id=630
    Sean
  • David Roth weiss
    April 9, 2008 at 5:10 am
    Steve,
    Below is one example of what you’re referring to from Newegg, at just $14.99. They have many others if you just search uisng the terms “USB to SATA.”
    https://www.newegg.com/Product/Product.aspx?Item=N82E16812156014
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
