Activity › Forums › Creative Community Conversations › Fascinating article on FCP.co today…
Posted by Marcus Moore on July 9, 2014 at 1:27 pm…brought to us by expert FCP X sleuth Alex Gollner.
As Alex points out, though this patent was submitted in 2009, it clearly shows some elements like Timeline Index, Magnetic Timeline and Auditions which would eventually find their way into X 3 years later.
The idea of narrative story structure begin represented in the edit software for the purpose of segmentation and collaborative editing is very interesting. Scenic Auditions? Yes please!
Well worth a read.
Richard Herd replied 12 years, 2 months ago 18 Members · 87 Replies -
Herb Sevush
July 9, 2014 at 1:47 pmAlex Gollner“Structure applies to feature films, TV shows, groups of corporate videos on an intranet, legal video depositions, architects’ video proposals or open-ended weekly web series. The more video applications can have these structures encoded in their projects, the better the tools they’ll be able to provide to a wider range of people all over the world.”
I couldn’t possibly disagree with this statement more. Since structure is fluid and dynamic what is required is a system that is totally open and pliable, able to be shaped to whatever structure can be imagined. Encoding structure into a system will inherently limit the structure to those imagined by the encoders.
“A story should have a beginning, a middle and an end, but not necessarily in that order.”
Jean-Luc GodardHerb Sevush
Zebra Productions
nothin’ attached to nothin’
“Deciding the spine is the process of editing” F. Bieberkopf -
Marcus Moore
July 9, 2014 at 2:03 pmI think we should consider a differentiation between creative structure and nuts and bolts delivery structure.
I agree with you completely that structuring embedded in an NLE shouldn’t inhibit creativity- absolutely.
But what if the structure is more to do with specifics of a broadcast delivery (commercial breaks), or even a TV series own internal, repetitive structure.
Pragmatically, any corporate video series, or commercial series, or TV series has repetitious elements. Making those things a known commodity in the structure of an edit- especially if these are things you can customize… that’s interesting.
Herb Sevush
July 9, 2014 at 2:18 pm[Marcus Moore] “Pragmatically, any corporate video series, or commercial series, or TV series has repetitious elements. Making those things a known commodity in the structure of an edit- especially if these are things you can customize… that’s interesting.”
Yes, that’s what nests and compound clips are for.
Herb Sevush
Zebra Productions
Franz Bieberkopf
July 9, 2014 at 2:25 pm[Marcus Moore] “… any corporate video series, or commercial series, or TV series has repetitious elements.”
Marcus,
Are you suggesting this is the core use case around which an NLE should be designed?
Franz.
Marcus Moore
July 9, 2014 at 2:35 pmI’m saying is a presents potential benefits to certain workflows.
If when you start a project you have the option to start with a blank page or open a project template where you’ve defined segment lengths, commercial breaks, lower3rd and inter-title styles, broadcast safe parameters… I’d like to see that.
Charlie Austin
July 9, 2014 at 3:04 pm[Marcus Moore] “The idea of narrative story structure begin represented in the edit software”
I honestly think this patent (minus the collaborative bits) better describes the trailer templates in iMovie. 😉
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Oliver Peters
July 9, 2014 at 3:40 pmInterestingly enough, this concept of segmentation of the timeline was suggested for FCP by Walter Murch a number of years ago.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
David Mathis
July 9, 2014 at 4:26 pmJust noticed Resolve 11 has an edit index, assuming this is some type of timeline index.
I am an avid user of FCP X!
Jason Porthouse
July 9, 2014 at 4:29 pmI would welcome some kind of story level range marking. I often cut docs with ‘scenes’ in mind, and the ability to quickly re-arrange those scenes to try out new story arrangements would be great, even if some finessing of the joins was needed later. It’s kind of formalising my ‘post-it note’ method of working out the arc of the narrative.
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes. -
Shane Ross
July 9, 2014 at 4:47 pmThe only repetitive element I’ve ever had in the TV shows I’ve worked on has been the title sequence. And that is usually a self contained element. Recently we’ve made them so that some elements are swapped out that reflect the current show we are one…but that’s easy enough without segmenting anything.
Shane
Little Frog Post
