Activity › Forums › Adobe After Effects › Far Vanish and Near Vanish AE Layers
  • Far Vanish and Near Vanish AE Layers
    Posted by Stephen Moore on August 13, 2019 at 8:37 am
    Hi All,
    I have a camera moving along the Z axis through a series of AE layers and I’d dearly love to be able to Far Vanish/Far Start Fade and Near Start Fade/Near Vanish those layers like in the Visibility tab in Trapcode Form.
    I’ve Googled around and found on (this essentially shows my scene)…
    https://macprovideo.com/article/after-effects/using-distance-from-camera-to-animate-in-after-effects
    …this code…
    start = comp(“Fade”).layer(“Control”).effect(“FadeStart”)(“Slider”);
    end = comp(“Fade”).layer(“Control”).effect(“FadeEnd”)(“Slider”);
    CameraPos = thisComp.activeCamera.toWorld([0,0,0]);
    LayerPos = toWorld(anchorPoint);
    Difference = length(CameraPos, LayerPos);
    linear(Difference, start, end,0,100);
    …which works for the Near Fade and this code…
    startFade = 500; // Start fade 500 pixels from camera.
    endFade = 1500; // End fade 1500 pixels from camera.
    try{ // Check whether there’s a camera.
    C = thisComp.activeCamera.toWorld([0,0,0]);
    }catch(err){ // No camera, so assume 50mm.
    w = thisComp.width * thisComp.pixelAspect;
    z = (w/2)/Math.tan(degreesToRadians(19.799));
    C = [0,0,-z];
    P = toWorld(anchorPoint);
    d = length(C,P);
    linear(d,startFade,endFade,100,0)
    …which works for the Far Fade.
    Does anyone know how to combine the two? That would be brilliant!
    Many thanks in advance…
    Stephen
    Daniel Poffley replied 3 years, 4 months ago 3 Members · 2 Replies
  • Cassius Marques
    August 13, 2019 at 2:25 pm
    Sure:startFadeNear = 300;
    endFadeNear = 600;
    startFadeFar = 800;
    endFadeFar = 1500;
    e = length(C,P);
    if (e<600)
    linear(e,startFadeNear,endFadeNear,0,100)
    else{
    linear(e,startFadeFar,endFadeFar,100,0)
    Cassius Marques
    http://www.zapfilmes.com
  • Daniel Poffley
    May 25, 2023 at 7:54 pm
    Hello. I am struggling to get this code to work.
    The far-fade is working perfectly, but the near-fade doesn’t seem to do anything. Does this code require any updating?
    Thank you in advance.
