Activity › Forums › Adobe Encore DVD › fancy highlights in menues
  • fancy highlights in menues
    Posted by Laurence Rietdijk on May 13, 2008 at 11:21 pm
    I’m trying to copy an effect that I have seen on comercial DVD’s where, rather than highlighting, a relivant picture will apear next to the button. These images are not neccisarily overlaping with each other or anything like that.
    At first I though you could incorperate the image into the highlight layer, but after reading the other blogs, I understand why you can’t do that. but I still don’t understang how you ‘do’ do it.
    Joe Bowden replied 18 years, 4 months ago 3 Members · 4 Replies
  • Jeff Bellune
    May 13, 2008 at 11:33 pm
    [Laurence Rietdijk] “I still don’t understand how you ‘do’ do it”
    You need duplicate menus – one for each button. Add the appropriate picture to each button on its respective menu. Edit each Menu Color Set to make the Normal highlight state transparent. Set each “non-picture” button on each menu to auto-activate and link to the appropriate dupe menu.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Laurence Rietdijk
    May 14, 2008 at 7:39 am
    I did what you said and it seems to work exept for one thing.
    Auto activate doesn’t seem to work if the user mover the mouse over it. It works when I use the cursors, so presumably it would work on a DVD Player. But is there a was to make it work on computer?
  • Jeff Bellune
    May 14, 2008 at 11:06 am
  • Joe Bowden
    May 14, 2008 at 2:25 pm
    Sorry, Laurence. This is one of the drawbacks of using a workaround to exceed the limitations of DVD-Video in regards to button highlights.
