Activity Forums Adobe After Effects fake 3d tag cloud – orientation question
  • fake 3d tag cloud – orientation question
    Posted by Ian Collister on December 21, 2011 at 10:34 am
    Hi all
    I have to re crate a tag cloud similar to this:
    https://www.roytanck.com/tag-cloud/
    I thought I would have each word on its own layer, space them out and rotate them around a null in the middle.
    How would I have them all keep their orientation to the camera? So they all continued to face the camera straight on as they rotate.
    Any help is always appreciated.
    Cheers
    i
    Ian Collister replied 14 years, 9 months ago 2 Members · 2 Replies
  • John Cuevas
    December 21, 2011 at 12:35 pm
    This works best if you use a camera with a far zoom, say the 200MM preset, if you choose a wide angle camera(18MM) the camera ends up being too close and the text will be shifting on both the x and y axis to keep facing the camera..
    Now just select all your text layers and (PC) press “cntl+alt+o” to open the orient dialogue and choose “Orient towards camera”
    Also there are expressions that could be written to achieve this too, but this is probably the fastest way to accomplish this look.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ian Collister
    December 28, 2011 at 10:14 am
    Thanks John, much appreciated!
