Activity Forums DaVinci Resolve Fairlight Smalest range for setting a key-frame?
  • Fairlight Smalest range for setting a key-frame?
    Posted by Don Cobble on November 5, 2020 at 6:36 pm
    I have noise spikes in a few places on an audio track that i would like to key-frame out, but, I cant set the key frames close enough to just remove the audio spike. Its there a setting that would allow me to edit closer than a frame to frame distance? if so what is it called please? I have l looked in the manual, and did not find, but it might be under a unique name. Sound Forge will allow editing in much smaller samples
    Thank You
    dc
    Don Cobble replied 5 years, 8 months ago 2 Members · 2 Replies
  • David Baud
    November 6, 2020 at 5:30 am
    You may want to check sample level editing in Fairlight. You just need to zoom into your track until you see control points. Once zoomed in you can “redraw” your audio level, in your case take out your spike in your audio. Make sure you have some markers or are working in a loop play mode so you don’t loose your editing spot.
  • Don Cobble
    November 24, 2020 at 4:01 am
    David – Thank You!!!!!!!! I did not that would do that!!!!
    Life saver!!!!!!
