Activity Forums Panasonic Cameras faint red in bottom 1/4 of frame?
  • faint red in bottom 1/4 of frame?
    Posted by Thom Zimmerman on October 17, 2006 at 6:16 pm
    I have a 27F with very low miles and I saw something the other day when I was white balancing. In the bottom 1/4 of the frame I saw a faint red gradation going from side to side. When I pulled out I couldn’t see it. Then when I zoomed in to shoot some awards tight and I saw it again. I was shooing wide open at the time but when I stopped down to a 4+ it appeared to go away. Has anyone seen this problem before? Thom Zimmerman
    Jeff Larson replied 18 years ago 4 Members · 4 Replies
  • John Sharaf
    October 17, 2006 at 6:51 pm
    Sound like a lens flare; if you see it again look at the front of the lens and if you can see a specular try to flag it off with your hand and see if it goes away.
  • Chris Bierlein
    October 17, 2006 at 10:18 pm
    Was it red or magenta? Was the gradation you refer to from top to bottom, or side to side-in other words, was the color getting stronger at the bottom of the frame, or at the side? If it’s magenta, it could be a white shading issue which becomes more apparent when you’re zoomed in all the way.
    Chris B.
  • Thom Zimmerman
    October 19, 2006 at 5:56 pm
    thahks for the reply. I just spoke with Jeff at Panasonic and we think it’s a shading problem also.Thansk again
  • Jeff Larson
    August 21, 2008 at 1:18 am
    What did you do to fix the problem? I’m asking because I have a DVX100A with the same problem. Please let me know if Jeff at Panasonic had a contact for general questions like these.
    Jeff
