Failed video exports and audio WAV files with wired issues
Hey all,
I tried batch exporting 9 sequences of concert recordings in HDV format but all of them failed. The way I did it is opened the PPro file in AME.
After the faild operation, I opened the files that AME had made and saw that only the first clip of each sequence had been exported. Because my clips are about 45min long it exported about 1/2 or 1/3 or 1/4 or a concert. I thought that the problem came from unrendered sections as I had put fade in and out to clips. So I rendered all red sections in the sequence and then reimported into AME and tried exporting again but same issue. Does anybody know where its coming from ?
Regarding the WAV audio files, I also setup an export of only audio of those sequences. The files are full length of the sequence however, they are mono on one side (left) and many of them seem to have issues as they seem to “lag” and play one sound only when I jump forward in the second half of it to listen to different parts.
Any ideas ?
motion pictures + storytelling = ?
-> FILMMAKING !
