Activity Forums Adobe Encore DVD failed in open of the ves file?
  • failed in open of the ves file?
    Posted by Tino Fisher on November 19, 2009 at 12:47 pm
    Hello,
    i’m working on a blu ray disk. After a long period of work i could solve most of the errors encore was bringing up. But now the following error occurs when i want to create the iso:
    failed in open of the ves file….
    Is that error known? how can i solve it?
    thanks
    Bill Russell replied 10 years, 6 months ago 3 Members · 2 Replies
  • Bill Macomber
    April 23, 2010 at 10:14 pm
    Hey, guys – This is an old post but it came up for me on a google search, so I wanted to answer it.
    Here’s a fix, from another forum:
    I have a new workaround which did get me past this particular problem so it will be interesting to know if it helps
    anyone else that encounters this error.
    I loaded the project as normal, tried to build it as normal and hit the same error – just checking that nothing miraculous had happened overnight.
    I then went into the AuthorScriptHDMVSessions folder (which is inside the folder named after the project) and deleted ALL of the files contained in there. I then got Encore to build the project again … and it worked!
    It seems that deleting those files causes Encore to re-import/re-analyse all of the assets and this corrects whatever is causing the problem.
    Memo to Adobe: PLEASE improve the error messages in Encore! They stink at the moment – they are almost totally useless in suggesting what the end-user can do to correct the problem.
  • Bill Russell
    February 16, 2016 at 12:37 am
    (Fast forwarding another six years to say… Thank you! Never encountered this before. Sigh.)
    “THE LOST SKELETON OF CADAVRA”
    And more…
