Activity Forums Adobe After Effects fail to key out black background in Avid
  • fail to key out black background in Avid
    Posted by Samya Chattopadhyay on February 14, 2012 at 7:24 pm
    Hi there…
    Something might sound silly.
    I am a newbie to AE. Created a simple text animation in CS4 and rendered it as Targa seq with alpha.
    But when I import it in Avid MC 4.0.3 over an existing video, it just covers the layers underneath.
    Can’t key out the black background in tagra…although there is no background in AE. The comp size in AE and Avid project setting is not exactly the same…could it be due to this?
    Samya Chattopadhyay replied 14 years, 7 months ago 2 Members · 2 Replies
  • John Cuevas
    February 14, 2012 at 8:02 pm
    Comp settings wouldn’t effect the alpha channel, but as an Avid editor/AE guy, you will save yourself headaches if you set your AE settings to your final settings in Avid. Avid just isn’t as flexible and when it resizes it will often cause some strange scaling issues and artifacting.
    As to the Targa issue, when you render it, in the output module make sure your video output is set to RGB + Alpha and in the format options change the resolution to 32 bits/pixel. See if that doesn’t solve the problem.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Samya Chattopadhyay
    February 16, 2012 at 4:32 am
    Thanks for the info…solved…
    The ’32 bpc’ thing has worked…although the ‘setting’ differences in Avid and AE didn’t seem to have posed any problem.
