Activity › Forums › Adobe Premiere Pro › Fades (transitions) not smooth
  • Vince Becquiot
    February 18, 2017 at 10:55 pm
    Hi Robert,
    It’s all about bit rate. I would start at around 20 Mb/s for Youtube HD in H.264.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Robert Gilbert
    March 6, 2017 at 7:36 pm
    Thanks, Vince.
  • Jeff Pulera
    March 6, 2017 at 10:35 pm
    I can’t speak for CS4, but at least since CS6 dissolves have never finished properly – they fade down to a point, then suddenly and prematurely just end abruptly. Most noticeable if you put a white title over black background and dissolve out. Play it frame by frame – opacity ramp down to transparent never finishes, just disappears short of completion.
    With CC, in Sequence Settings, uncheck Composite in Linear Color. Also turn OFF the GPU rendering before exporting, see if that helps.
    Jeff
  • David Huettner
    December 21, 2017 at 5:48 pm
    I couldn’t see OP’s vid, but I experienced a similar issue with fade opacity ramp ending abruptly. Unchecking Composite in Linear Color worked! Thank you!
