Activity Forums Maxon Cinema 4D Fade up objects with sketch material applied
  • Fade up objects with sketch material applied
    Posted by David Wiffen on January 16, 2009 at 11:40 am
    Hi Everyone,
    Simple problem…
    I need to fade up objects that have sketch and toon materials applied.
    The normal way I fade objects up is to use a display tag and animate the visibility percentage. This works fine for normal materials.
    But when a sketch material is applied it doesn’t fade – justs pops on at the keyframe.
    The way I am doing it currently is to animate the opacity of all my materials, but in terms of workflow this is a nightmare way to do it i.e. lots of materials and lots of separate animations. So if i decide to change one element…all elements have to be changed.
    Is there a better way to do it?
    Thanks chaps.
    David Wiffen replied 17 years, 8 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    January 16, 2009 at 3:58 pm
    I don’t know if it’s a *better* way, but another way would be to render a sketch/poste effects pass and use object buffers to split up the objects and fade them in/out in post … but that might be a bigger PITA than what you’re doing now.
    Another option would be to use Xpresso to drive the opacity of multiple materials with the opacity of one material.
  • David Wiffen
    January 16, 2009 at 4:01 pm
    Thanks Adam,
    Both of these are really good ways. I was thinking xpresso could have been the solution, then maybe a HUD slider for ultimate ease of access.
    Thanks for your help.
