Activity Forums Adobe After Effects fade to black animated text?!
  • fade to black animated text?!
    Posted by Vin2000 on October 9, 2007 at 3:33 am
    Does anyone know how to “dissolve to black” the entire text at once?
    Under “Animated Out” I see some fading out, by they either scroll fading out, or one word at a time. I’d like to fade out the entire text at the same time.
    Thanks in advance!
    Vin.
    Vin2000 replied 18 years, 11 months ago 2 Members · 4 Replies
  • Michael Duff
    October 9, 2007 at 3:36 am
    do you mean fading out the entire layer?
    just select the layer and hit “t” to reveal the opacity setting … press the stop watch to enable keyframing … it should be on 100% for where you want the dissolve to start … go to where you want it to end and make the value 0%… it will dissolve out between those two keyframes
    is this what you meant?
  • Vin2000
    October 9, 2007 at 3:42 am
    Hi there,
    thanks for the quick response.
    i’m doing ending credits for a film, so i have black background white text.
    i want to fade out all the text at the same time to get to a black screen again.
    i tried what you told me to do, but on the keyframe, if i put it on 0% on the 2nd keyframe (where i’d want to do dissolve to black) then the 1st one automatically adjusts itself to 0% as well, and vice versa with the 100%…
  • Michael Duff
    October 9, 2007 at 3:57 am
    you must just have them both selected … are they both yellow? rather than grey? this means they are both selected … click away from the layer and try again
  • Vin2000
    October 9, 2007 at 3:59 am
    they were both selected, it’s all good now, thanks!
    i have more “newbie” questions coming up, but thanks again for the quick replies!
