Activity Forums Adobe After Effects Expressions Fade Out at Marker End
  • Fade Out at Marker End
    Posted by Henri Yates on November 18, 2022 at 6:20 pm
    Hello… I want to add an expression to another expression to add a slight fade (like 5 or 6 frames) out to a text layer. I don’t want it to disappear abruptly.
    Here’s the expression;
    m = thisLayer.marker;
    n = 0;
    val = “”;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (m.key(n).time > time) n–;
    if (n > 0){
    t = time – m.key(n).time;
    if (t < m.key(n).duration){
    val = m.key(n).comment;
    val
    Thanks.
    Henri Yates replied 3 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 18, 2022 at 6:37 pm
    I’m assuming this is a source text expression, correct? If so, change it to this:
    n = 0;
    val = "";
    if (m.numKeys > 0){
    if (m.key(n).time > time) n--;
    if (n > 0){
    val
    and add this opacity expression:
    f = framesToTime(5);
    n = 0;
    val = 0;
    if (m.numKeys > 0){
    if (n > 0){
    t = time - m.key(n).time;
    d = m.key(n).duration;
    val = linear(t,d,d+f,100,0);
    val
  • Henri Yates
    November 18, 2022 at 6:43 pm
    Thank you, Dan Ebberts.
