Activity › Forums › Adobe After Effects › Fade in & out question
  • Fade in & out question
    Posted by Norman Greenwood on May 13, 2009 at 7:53 pm
    How can I fade in an object from left to right, or from top to bottom, or vice versa?
    For example, if I placed a red rectangle in the middle of a photograph, and wanted it to appear by fading in from its left-side to its right-side, then disappearing by fading out from its left-side to its right-side, how would I go about doing this?
    It seems like it should be something easy to do, but I can’t quite figure it out.
    Thanks for the help.
    Zach Gunter replied 17 years, 4 months ago 3 Members · 3 Replies
  • Kevin Camp
    May 13, 2009 at 7:45 pm
    i think you’re looking for the linear wipe effect (effects>transitions>linear wipe)
    it will wipe a layer on or off in any direction you want and has feather control to soften the edge as it wipes on.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Norman Greenwood
    May 13, 2009 at 9:01 pm
    Thanks, Kevin. I knew it would be something simple. I’m one of those overanalyzer types.
  • Zach Gunter
    May 15, 2009 at 9:32 pm
    another way would be to make a mask for it, click on your layer, hit ctl+shift+N feather your mask out and animate it. this would give you more control later if you needed it.
    Frozensmokeprod@aol.com
