Activity › Forums › Apple Final Cut Pro Legacy › fade in fade out disolve
  • fade in fade out disolve
    Posted by Ross Green 25 on January 9, 2006 at 11:38 am
    I am new to Final Cut Pro and I am having a problem with the fade in fade out disolve. I am using Final Cut Pro 5 HD, and the problem that I am having is that when applying a fade in fade out disolve to the end of a clip it works fine, however when applying it to the beginning I can only add one frame? If anyone can help I will be extremely grateful.
    Thaxter Clavemarlton replied 20 years, 8 months ago 2 Members · 1 Reply
  • Thaxter Clavemarlton
    January 9, 2006 at 4:24 pm
    If you are trying to add a DISSOLVE…
    (do not use the “Fade-In/Fade-Out” Filter at the HEAD of a timeline or section, unless you have a very specific “need” for it)
    you need the clip to have enough “extra” footage so that the dissolve has the frames that it needs to “mix”.
    At the HEAD of a clip (coming from BLACK) you could change the Dissolve to “Start on Edit” if there not enough “pre-clip handle” frames for “End on Edit” or “Center on Edit” to work.
