Activity › Forums › Adobe After Effects Expressions › Fade In and Out
Fade In and Out
Posted by Deepak Kumar on January 3, 2019 at 5:41 pmCan anyone Plz describe me How This Expression Work? When i Appy this Into Opacity it Makes Laye fade in and Fade Out I want To know physics behind it.
i = linear(time, inPoint, inPoint+.5, 0, 100);
o = linear(time, outPoint-.5, outPoint, 0, 100);
i-oDan Ebbertsreplied 7 years, 8 months ago 3 Members · 4 Replies
Kalleheikki Kannisto
January 3, 2019 at 6:02 pmVariable “i” gets its value from remapping the time value between the inpoint time of the layer and the inpoint time plus 0.5 seconds to the range of 0 to 100. Thus at inpoint the value of i is 0, from where it rises up to 100 in the following 0.5 seconds.
Variable “o” gets it’s value similarly (in reverse) at the endpoint of the layer by remapping time from 0 to 100.
When you subtract o from i you get both variables affecting the opacity.
To understand the linear() function better, check it out in the AE expressions reference.
Senior Graphic Designer -
Deepak Kumar
January 8, 2019 at 9:02 amWhy Only subtract Works Perfect Why It Doesn’t when i do “i + o”
January 8, 2019 at 12:38 pmIf you add the values then in the end it goes from 100 to 200, not 100 to 0.
Dan Ebberts
January 8, 2019 at 2:17 pmHere are a couple of other ways to do it that might make more sense (because the calculation for o goes in the direction you expect):
o = linear(time, outPoint-.5, outPoint, 100, 0);
Math.min(i,o)i = linear(time, inPoint, inPoint+.5, 0, 100);
time < (inPoint+outPoint)/2 ? i : oDan
