Activity › Forums › Adobe After Effects › Fade In and Out random layers in a composition.
  • Fade In and Out random layers in a composition.
    Posted by Brandon Gregory on May 7, 2017 at 2:13 am
    So I have 4 layers in a composition. It’s the same image repeated, except each one has a different Photoshop effects on them. What I want to be able to do is an opacity fade from one randomly selected layer to another. Would really appreciate the help.
    Remus Hosu replied 9 years, 2 months ago 2 Members · 2 Replies
  • Brandon Gregory
    May 8, 2017 at 2:06 am
    I’m sorry, so is that your way of saying you can’t help? Do I have to assure you that I do need this? I don’t understand…
  • Remus Hosu
    July 29, 2017 at 4:11 pm
    You can try with a fade expression for the layers. After you apply it to one layer you can copy the expression and select random layers and choose “Edit” – Copy Expression Only.
    Here’s the expression:
    fadeInTime = .5; // time (seconds)
    fadeOutTime = .5;
    Math.min(linear(time,inPoint,inPoint + fadeInTime,0,100),linear(time,outPoint – fadeOutTime,outPoint,100,0))
    If you’re not sure how to do it, here’s a tut on that:
    https://bluefx.net/how-to-add-opacity-to-layers-footage-after-effects
    Hope this helps
    https://bluefx.net
