Fade and Transition
Posted by Thayalan Paramasawam on December 21, 2012 at 12:47 amHi,Good Morning Sir,
On preview the playback not smooth,its jerk at fade or transition area.What should i do,pls help me on this matter.
Thank You
Thayalan ParamasawamThayalan Paramasawam replied 13 years, 9 months ago 3 Members · 4 Replies -
Steve Rhoden
December 21, 2012 at 2:19 amIm not clear what you mean, but right click on the
preview window and make sure
Adjust size and quality for optimal playback is not selected.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-832-4956 -
December 22, 2012 at 12:43 amHi,Good Morning Mr.Steve.
Now my playback is smooth.
Thank Very much for your adivice.Thank You
Thayalan Paramasawam -
Matt Crowley
December 22, 2012 at 8:47 amTransitions take a lot more processing power to preview compared to straight video sections of your project. That’s because Vegas is decoding 2 video streams and doing blending or other effects (blur, distort etc depending on the transition type) on the 2 decoded video streams. The amount of work that needs to be done depends on the preview quality setting.
You may see some stuttering or jerky playback the first time you preview a transition. Try t o play the transition a few times and it will get smoother as Vegas caches more of the rendered transition frames.
December 23, 2012 at 1:35 amHi Good Morning Sir,
Thank You very much Mr.Matt Crowley for the adivice…
Thank You
