Facetracker – 3d rotation
I’m trying to track a face using the inbuilt face tracker. I can’t seem to find a method to track rotation (depth – not x/y). I want to take the tracked points into Cinema 4D and use them to create animations to then reapply to the face footage. For example, when a head turns to the left or right i want to be able to track the points in a 3D space.
I don’t want to use physical tracking markers (hence the AE face tracker). I’ve tried the 3D camera tracking and to see if i can trick it but it keeps failing and i’m guessing this is because there’s not actual camera movement??
Any tips for this would be a massive help!
Thanks in advance,
Andy
