Activity Forums DaVinci Resolve Eye popping color in Resolve-fades after compression?
  • Eye popping color in Resolve-fades after compression?
    Posted by Matt Stoltz on May 27, 2016 at 2:02 am
    Hey all
    So I know Resolve presents colors in an awesome way. When I grade everything look vibrant, rick blacks and so forth. But what is the trick to maintain that nice color when compressing it for the web. Quicktime X just makes it dull and flat sometimes and the client comes back and says can I add more saturation.
    i also ask because when I watch movie trailers and downloaded movies in Quicktime -they seem to be very colorful as well-
    what am I missing in my workflow?
    thanks
    Matt
    Matt Stoltz replied 10 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Karsten Fischer
    May 27, 2016 at 7:07 am
    Maybe something like this: https://forums.creativecow.net/thread/277/34925
    Ever tried. Ever failed. No matter. Try again. Fail again. Fail better.
  • Matt Stoltz
    May 27, 2016 at 1:13 pm
    hey -YES exactly like that. Ok I understood a little of what he meant but how do you check all that. whats the trick.
    thanks for your help
    matt
  • Joseph Owens
    May 27, 2016 at 10:52 pm
    If it is my post, I’ve added an update.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Karsten Fischer
    May 30, 2016 at 7:43 am
    Look at these settings in Color Management in the project settings:
    Resolve can manage that for you if you are in a hurry or working local TV news, which means you’re always in a hurry. Otherwise, just as Joseph pointed out, make sure your levels are within 64-940 since everything above or below is getting clipped.
  • Matt Stoltz
    May 31, 2016 at 4:21 pm
    hey Karsten
    ok i looked at those settings and Input and output color spaced are greyed out –they are set on 709 2.4 but i can’t change them
    Joesph -thanks for the update -much appreciated
    matt
  • Karsten Fischer
    June 1, 2016 at 9:27 am
    Hi Matt,
    that certainly is unexpected. OK, if you don’t care about proper levels for broadcast you can, of course, go to the deliver page in Resolve and tweak the output settings to export the full data levels (in the 12.5 beta you’ll find those within the video panel under advanced settings) instead of “Auto”.
  • Matt Stoltz
    June 3, 2016 at 11:47 pm
    Yes I look at the output options and I set the video levels to 64 and 960 option I took it off auto but there was no option to set the output for rec709 gamma 2.4 -so I hope I did it right –
    Now when I Bring it into Premier cc 15 will my video levels automatically be set like that or do I to check something else in premiere
    Matt
