Activity › Forums › Maxon Cinema 4D › Extrusion with Shader effector?
  • Extrusion with Shader effector?
    Posted by Louis Hamwey on April 8, 2015 at 6:30 pm
    I am trying to make a logo half flat (2d object) to extruded (3d) at a gradual rate, similar to the image below. I tried to use a shader with a gradient to get this effect, but I couldn’t get it. IS this the best way to go about it or is there another method someone would recommend?
    Brian Jones replied 11 years, 5 months ago 2 Members · 1 Reply
  • Brian Jones
    April 9, 2015 at 1:27 am
    going to be hard to get the exact same look as a vector fake but if you had Lofts rather than extrudes you could loft from one copy of a spline to another then just lift one side up a bit with a soft selection (etc more than one way to do that) – you would still have to use gradients in the textures but that’s easy enough
