Activity Forums Maxon Cinema 4D Extruding problem
  • Extruding problem
    Posted by Kfirluvko on September 16, 2007 at 12:03 pm
    Hey this is kinda basic question since im pretty new at cinema 4d.
    How do i extude a single surface on a polygonal cube with several segmants?
    When i try to extrude a single part of the cube all the segmants around it getting extruded as well which is not what i wanted to do…
    Brian Jones replied 19 years ago 2 Members · 3 Replies
  • Brian Jones
    September 16, 2007 at 3:37 pm
    select the face you want to extrude first, then use the extrude tool. (Which you can use anywhere in the view – it doesn’t have to touch the object)
  • Kfirluvko
    September 16, 2007 at 5:48 pm
    Yeah i chose the face i wish to extrude the thing is the faces around are being distorted when i try to extrude this one face-so the question is how do i extrude this face alone.
  • Brian Jones
    September 16, 2007 at 6:09 pm
    I’d have to see the geometry, extrude doesn’t usually affect surrounding geometry… unless you got it in a HyperNurb
