Activity › Forums › Adobe After Effects › Extruding an object through a plane
  • Extruding an object through a plane
    Posted by Sean Mclean on August 25, 2015 at 12:34 am
    Hello,
    New to AE, but learning the basics quick. I’m working on putting together an introductory scene to my aerial videos, and I would like to extrude my logo through the plane. I’ve already generated a 3D version, and figured out basically how I want the rest of the intro to work. Please see here for what I’m working on: https://www.youtube.com/watch?v=t7OaLD2Tls4
    Basically, I’d like the first 1-2 seconds to be of that logo emerging from the white background, like something being extruded out of a playdough machine.
    Any tips for how to make this work? I tried to push it through the Z-Plane, but there doesn’t seem to be any wiggle room there. It’s either all the way in front of the background layer, or all the way behind it.
    Sean Mclean replied 11 years, 1 month ago 3 Members · 4 Replies
  • John Cuevas
    August 25, 2015 at 2:00 pm
    How did you make your 3d logo, with 3D render in AE, or is it from another program?
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Daniel Waldron
    August 25, 2015 at 2:01 pm
    How did you make the 3D text? Ray-traced? Element 3D? If your text is 3D (which it pretty clearly is) and your white background is a solid layer in 3D space, then, in theory, you should be able to achieve what you are aiming for.
    If you used a plug-in like element 3D, you could always make the background in Element and animate the push through with the plugin’s animation controls.
  • Sean Mclean
    August 27, 2015 at 12:19 am
    3D Text was made with Element 3D. I’ve tried it both with the white background layer (which is 3D), and also with creating a 3D layer that was extruded a smidge. In either case, when moving the logo through the Z space, it’s either entirely viewable, or entirely blocked. For example, when I tried with the extruded layer, I made that .25 thick, and my logo 3.0.
    Here’s an example using the background. Completely blocked at 0. Completely visible at .1.
    https://www.dropbox.com/s/igkiot4hactd6i1/z%3D0.PNG?dl=0
    https://www.dropbox.com/s/ajgishkp2810sm6/z%3D.1.PNG?dl=0
  • Sean Mclean
    August 27, 2015 at 2:04 pm
    Figured it out! Suggestion nailed it, I added the plane as another object in Element 3D, which allowed me to get the extrusion effect.
    https://www.youtube.com/watch?v=gk4ibWPId4A
    Now time to redo the rest 🙂 Thanks!
