Activity Forums Boris FX Extruded EPS – Mapping extruded shape – SOny vegas
  • Extruded EPS – Mapping extruded shape – SOny vegas
    Posted by Guillaume Jeffrey on February 28, 2011 at 7:11 am
    I want to map my extruded shape with a picture.
    I use the texture menu set to source layer (picture added as take), then the preview window becomes red, vegas (10c) stops responding & i have to shut it down manually.
    What are the solutions to map a shape?
    John Rofrano replied 15 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    February 28, 2011 at 2:08 pm
    [Guillaume Jeffrey] “I use the texture menu set to source layer (picture added as take), then the preview window becomes red, vegas (10c) stops responding & i have to shut it down manually.”
    This should not be happening but I would not add the picture as a take. I would add BCC Extruded EPS to the actual picture as an event. You can get strange results when adding FX to empty events, which use the project dimensions, and then adding takes which may have other dimensions.
    Also make sure that your display drivers are up to date and that you are using the latest BCC 7.0.4. BCC7 uses OpenGL acceleration so having good OpenGL drivers is important.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Guillaume Jeffrey
    March 1, 2011 at 12:58 am
    Thanks again John! I add the effect directly on the picture event and no problem.
    By the way, how to map a different picture on the front and back of the extruded EPS as the only choice for texture is “none” or “source layer”?
  • John Rofrano
    March 1, 2011 at 1:30 am
    [Guillaume Jeffrey] “By the way, how to map a different picture on the front and back of the extruded EPS as the only choice for texture is “none” or “source layer”?”
    Use Texture File instead of Texture Layer. You can map a different texture to front, back, side, and bevel.
    ~jr
