Activity Forums Adobe After Effects Extrude boarders of a map
  • Extrude boarders of a map
    Posted by Dennis Squadrazzino on August 22, 2017 at 9:58 am
    Hi dear community,
    Herer is the short version of my question:
    I want to do something like this: https://www.youtube.com/watch?v=7NIICVIZd50
    with an old map, but can not extrude the part of the map i cut out in Photoshop in After effects.
    Maybe you can help me with my problem:
    I have a map with land and ocean on it. I want the land to be extruded, so on higher level than the ocean and with a stroke around it.
    I already tried this way:
    -Cut out the land in Photoshop
    -Import it into Illustrator-save
    -Import into After Effects with Ray traced 3d
    -set the Bevel in Geometrie options – i just got a grey box
    I guess the first two steps are ok, but i need help with the next step after these, as After effect will not take over the AI layers correctly:
    -Import directly into After Effects
    and now i need to take over exactly the shape of the land that i cut out in Photoshop on a shape layer. So for example, a shape layer needs to be the exact form of the Photoshop layer of Italy i cut out.
    It should be looking like this:
    https://www.youtube.com/watch?v=V_4d0Teaoko
    (around 20 sec.)
    Any ideas, how to do that? Or maybe there is an easier way?
    Dennis Squadrazzino replied 9 years ago 2 Members · 2 Replies
