Activity › Forums › VEGAS Pro › extremely long render times
  • extremely long render times
    Posted by Dale Parsons on August 17, 2014 at 3:51 am
    It is taking 3.5 hours to render an 18min video.
    Is this normal? Is there some codec I can use to improve things? I have a Core i5 CPU and 335m nVidia GPU.
    John Rofrano replied 12 years, 1 month ago 3 Members · 6 Replies
  • John Bolton
    August 17, 2014 at 11:05 am
    May need a bit more info…What is the Media you are rendering- HD / SD, etc and what are the project setting. Did you Match the Project settings to the media? What are the render settings you are using for the Final output?. Regards John
  • John Rofrano
    August 17, 2014 at 2:58 pm
    [Dale Parsons] “Is there some codec I can use to improve things? I have a Core i5 CPU and 335m nVidia GPU”
    The Core i5 is part of the problem. You really need a Core i7 for video work. I know a lot of people use Core i5’s but usually these people don’t care about rendering times and would rather save a few dollars. Intel suggests using Core i7’s for content creation. Get a 6 core or 8 core if you really want to render faster.
    Once you answer John’s questions above we can probably help get things working faster but it’s never going to be as fast as a better CPU would be.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dale Parsons
    August 17, 2014 at 5:31 pm
    It’s 1080p30. Project settings are same as the media 1080p30. He are the render settings…
    With 720p rendering it’s significantly better (estimated 1.5hr. Didn’t complete the render though. I was just checking.)
    I noticed the text effects slow things considerably as well. I tried running Vegas with 335m engaged instead of integrated and it kept crashing during the render.
    Just a question, it seems x264 isn’t usable with Vegas, but is it faster? I used to use a program called Videopad and I seem to remember it took just a few minutes to render 20 min of video with that codec…I could be remembering incorrectly, but it certainly didn’t take 1.5 hours to render 15min…
  • John Rofrano
    August 18, 2014 at 11:37 am
    [Dale Parsons] “Just a question, it seems x264 isn’t usable with Vegas, but is it faster? “
    Are you referring to the x264vfw codec? It’s available in Vegas if you install it and manually create a template for it. You need to make your own templates for any codecs that you install outside of Vegas.
    [Dale Parsons] “I used to use a program called Videopad and I seem to remember it took just a few minutes to render 20 min of video with that codec…I could be remembering incorrectly, but it certainly didn’t take 1.5 hours to render 15min…”
    Render time is not just the time it takes to encode the file, it’s also the time it takes to create any FX you have applied to the video. So rendering a video with no FX will be faster than rendering a video with heavy FX using the same render settings.
    ~jr
  • Dale Parsons
    August 18, 2014 at 2:19 pm
    Yes, exactly, that is what I meant. Thank you.
    What do you think about this codec regarding quality, speed and compatibility with YouTube (in terms of YouTube re-rendering and end result quality) vs Sony’s default.. Main Concept
  • John Rofrano
    August 21, 2014 at 10:44 am
    [Dale Parsons] “What do you think about this codec regarding quality, speed and compatibility with YouTube (in terms of YouTube re-rendering and end result quality) vs Sony’s default.. Main Concept”
    I deliver MainConcept AVC to YouTube using the Internet 720p template and I don’t have a any problems with quality. I prefer MainConcept over Sony simply because it renders faster with my ATI Radeon HD 5870 GPU.
    ~jr
