Activity › Forums › Adobe After Effects › Extraperlate constant movement before and after keyframes
  • Extraperlate constant movement before and after keyframes
    Posted by Mike Futcher on October 25, 2018 at 10:11 am
    Hello After Effects people.
    I’m new to after effects, though I’m an experienced 3D animator with Blender.
    I’m creating a video that will contain a lot of images scrolling past at a constant rate. From what I understand I can create a null and parent everything to it, but… is there a way I can set two keyframes – say at position 1 at frame 100 and position 2 at frame 200 and have the null move at the same constant rate both before frame 100 and after frame 200?
    Thanks in advance,
    Mike
    Mike Futcher replied 7 years, 11 months ago 2 Members · 2 Replies
  • Walter Soyka
    October 25, 2018 at 2:34 pm
    You can use an expression. Alt+click on the stopwatch icon for the position property, then paste in this code:
    if (numKeys > 1) {
    if (time < key(1).time) loopIn("continue")
    else loopOut("continue");
    } else value;
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mike Futcher
    October 25, 2018 at 4:45 pm
    Wow – I didn’t think I’d be entering code so early, but you’ve explained very clearly how to do it – thanks!
