Activity Forums Maxon Cinema 4D extracting splines from a primitive
  • Adam Trachtenberg
    September 14, 2010 at 2:48 pm
    I would extrude a triangle spline, make it editable, and then weld the top points to form the 3-sided pyramid. Then you can use an Atom Array to get pipes on the edges, or clone a cylinder on the pyramid using edge mode with edge scale active. Or you could select the edges of the pyramid and do a Structure>Edit Spline>Edge to Spline and then sweep the resulting spline … but that will present some twisting and junction problems.
  • Holby Larsen
    September 14, 2010 at 2:58 pm
    thanks
    I find it very difficult to align the three triangular spline edges, is it possible to get that perfect?
    fubbi.com
  • Brian Jones
    September 14, 2010 at 5:27 pm
    use a Cone
    Top Radius 0
    Bottom Radius 100
    Height 141.418
    Height Segments 1
    Rotation segments 3
    Caps – Off
    Toss that into an Atom Array
  • Adam Trachtenberg
    September 14, 2010 at 5:56 pm
    Or use the N-Sided spline primitive with sides set to 3.
  • Brian Jones
    September 14, 2010 at 6:26 pm
    hmmm… Platonic Tetra too I see but where’s the fun in that 🙂
