Activity › Forums › Apple Final Cut Pro Legacy › External video monitor on an iMac G5
  • External video monitor on an iMac G5
    Posted by Nielsenr on November 24, 2005 at 4:32 pm
    Hi!
    I recently purchased an iMac G5 running FCP5 to replace my PC running Avid. On my old PC I had an external video monitor connected to my Matrox video card (via composite – but it looked great) which worked great.
    I would like the same on my iMac. How can I connect a video monitor, or is that only possible on the PowerMacs with e.g. a Decklink card?
    Is there a firewire interface that I can get or something or what are my options?
    Best regards, Rasmus Nielsen.
    Jack Fox replied 20 years, 10 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    November 24, 2005 at 6:53 pm
    Just connect your DV camera or deck to the iMac, then use firewire as the external video monitoring path. Then take the analog outs from your deck/camera to a monitor. Or you can use an advc-110 from Canopus and monitor DV externally that way.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jack Fox
    November 26, 2005 at 12:23 am
    Jerry,
    What can we expect from the Apple DVI to S-Video adapter?
    jmf
