Activity Forums Apple Final Cut Pro Legacy External Video in Final Cut on an iMac
  • External Video in Final Cut on an iMac
    Posted by Dan Weig on March 1, 2010 at 4:50 pm
    I’m planning to buy an iMac for an off-line editing system, but I need to see my Final Cut project’s external video. I don’t want to go through the Firewire port (I need that for my Firewire 800 external media drive), so I’m planning to purchase a Matrox MXO2 mini. I’m going to use the mini display port, using a HDMI adaptor to hook up to the Matrox MXO2 mini and hook that to a 1080p monitor. Does this make sense? Will this work, or is there a better way, without spending lots of money?
    Shane Ross replied 16 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    March 1, 2010 at 5:26 pm
    [Dan Weig] “I’m planning to buy an iMac for an off-line editing system,”
    OK, this is a fine idea…
    [Dan Weig] “), so I’m planning to purchase a Matrox MXO2 mini”
    This is not. The MXO2 mini will not work with an iMac. It requires a PCIe slot, something an iMac lacks. Or an Express34 slot…that only the 17″ MacBook Pro offers. Your only option is the original MXO, that connects via DVI. And Walter Biscardi (a head you see above) will be testing this out on older iMacs soon.
    [Dan Weig] ” I’m going to use the mini display port, using a HDMI adaptor to hook up to the Matrox MXO2 mini and hook that to a 1080p monitor. Does this make sense?”
    Nope. While the Mini takes in HDMI, and outputs HDMI, the way that it interfaces with the computer is via PCIe or Express34. Without THAT connection, your plan won’t work.
    [Dan Weig] “Will this work, or is there a better way, without spending lots of money?”
    Original MXO…or 17″ Laptop…or refirb MacPro (I’ve bought that way for years), or NOTHING, as this is an offline machine.
    Shane
