Activity Forums Apple Final Cut Pro Legacy external preview on cam ok but not previewing on tv
  • external preview on cam ok but not previewing on tv
    Posted by Sam Turner on March 7, 2006 at 10:46 am
    i have scoured the archive and found all the walthroughs and step by steps but i am still having some problems
    when i scrub the timeline i only get the odd frames appearing on the camcorders display (start, a few skippy frames during scrub and then the end)
    when i playback properly, the preview on the cam plays back in real time
    but i get no video signal going to my tv, only the preview
    could it be a camcorder problem (it plays back dv tapes fine when they are in the deck)
    how do others preview to a monitor? the next option would be to get a cheap card to drive the monitor, idealing something that will output to composite video so i can plug direct into my tv
    thanks
    ds
    Sam Turner replied 20 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    March 7, 2006 at 11:54 am
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Sam Turner
    March 7, 2006 at 2:20 pm
    thanks for that (had come accross the #8 tip many times in my searches)
    will try again, but think i will have to assume that its the camcorder thats the problem
    it previews the cam fine, but what i see on screen on the cam is not what i see on the tv
    have fun
    ds
