Activity › Forums › Adobe After Effects › External NTSC HD monitor
  • External NTSC HD monitor
    Posted by Tylor Larson on November 8, 2011 at 4:37 pm
    What are some options for setting up and external HD NTSC monitor for After effects? What kind of hardware will i need, and how large should my budget be?
    Jeff Brown replied 14 years, 10 months ago 2 Members · 7 Replies
  • 7 Replies
  • Jeff Brown
    November 8, 2011 at 5:04 pm
    What kind of work are you doing?
    -jeff
  • Tylor Larson
    November 8, 2011 at 5:14 pm
    Motion graphics work for HD broadcast.
  • Jeff Brown
    November 8, 2011 at 5:21 pm
    I’d suggest:
    Blackmagic or AJA i/o hardware,
    a Flanders Scientific, Panasonic, or JVC, broadcast SDI-HD monitor.
    Hardware waveform/vectorscope if you can possibly afford it; I cheat a little by using a composite signal to an SD waveform monitor, but it still shows me where things are, and in real-time.
    I’m sure there are other valid opinions & options, though.
    -Jeff
  • Tylor Larson
    November 8, 2011 at 5:23 pm
    which black magic card do you suggest?
  • Jeff Brown
    November 8, 2011 at 10:53 pm
    I’m a little out-of-touch with the BlackMagic products; I personally use an AJA card (Kona 3). But if you don’t need SDI or analog capture, and not many of us do anymore, I think they have at least one output-only card. SDI and SDI-HD out is really the key; the broadcast monitors I know of don’t use DVI/HDMI. I’d also suggest that the monitor you select does native 1080×1920 (pixel-to-pixel, without scaling); that may require a 24″; but I haven’t been shopping for a few years.
    -jeff
  • Tylor Larson
    November 8, 2011 at 11:05 pm
    Thanks Jeff,
    That really was helpful. i will keep that in mind about the SDI out only card. I didn’t know about the pixel scaling happens with consumer monitors.
    TY
  • Jeff Brown
    November 9, 2011 at 3:40 pm
    Tylor,
    I also remembered that BlackMagic has an “HD ‘scopes on a card” card. Does require a 2nd computer to host it, but all in all could be a cost-effective way to get real broadcast-level hardware ‘scopes.
    There might be others I’m not aware of…
    -Jeff
