Activity Forums Apple Final Cut Pro Legacy External monitoring through AJ-SD93’s analogue ports.
  • External monitoring through AJ-SD93’s analogue ports.
    Posted by Wally Tham on June 27, 2005 at 4:10 pm
    Hello All,
    Yet again I seek the collective wisdom of the Internets. 🙂
    I’ve a friend asking if he can get his AJ-SD93 to send out a signal to a TV. He’s connected via Firewire to the deck and a BNC to RCA cable to the TV. Had a quick look today couldn’t get it to work.
    He’s presently working on a DV project and I noticed the deck on DVCPRO50 mode, is that a problem?
    Wally
    Doug Olin replied 21 years, 2 months ago 2 Members · 1 Reply
  • Doug Olin
    June 27, 2005 at 5:42 pm
    Make sure the video input setting on the front of the deck is in the firewire setting and it should pass the video through to the analog video out. It works in similar fashion on an AJ-D95 deck we have.
    Doug Olin
    Pensacola Christian College
    G5 DP 2.0, 2 GB RAM, FCP HD, IO, OS 10.3.9, Medea RT3X 1200 GB
