Activity Forums Adobe Premiere Pro External Monitor
  • External Monitor
    Posted by The Jersey devil on December 9, 2005 at 9:40 pm
    Greetings from the Rocky Mountains!
    Can a computer monitor be used instead of a TV as the external monitor in Premiere Elements?
    If so, would it come off my dual head video card or through firewire?
    Technically, how would I hook this up?
    Thanks in advance.
    Mike Velte replied 20 years, 9 months ago 3 Members · 2 Replies
  • Don Huckleberry
    December 9, 2005 at 11:31 pm
    You should use an NTSC monitor because the color space is different than the RGB computer monitor.
    You might ask the question in the Premiere Elements forum too in case it’s something different than Premiere Pro.
  • Mike Velte
    December 10, 2005 at 12:34 pm
    No, Elements cannot display previews to a second computer monitor, but just like Pro, can pass thru a DV signal using your camcorder to a TV.
    Previewing video targeted for TV on a PC monitor is frought with peril.
