Activity Forums Adobe Premiere Pro External Monitor Woes
  • Peter Garaway
    June 21, 2013 at 8:01 pm
    Hi guys,
    This is a new setting for Premiere Pro CC. Many users wanted to ability to quickly enable and disable Transmit without having to go inside the preferences. Also note that you can create a keyboard shortcut for this feature too.
    Just for the record Transmit is enabled by default.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Robert Brown
    June 22, 2013 at 1:58 am
    I’m having issues too with the BM card. I have a kona but haven’ tried installing that. I get video that turns on and off during playback from the T/L through the BM at about 4 times a second. Vid black vid black…. It appears ok if I match in and play from the source viewer. Also I believe this was OK until I upgraded PPro CC to the patch that came out the other day but not positive.
    Also I thought the video card specific sequence settings had gone away. Kind of confused to see those back again at least for the BM card. Maybe that’s only for the BM codec. The sequence settings had no effect, tried several. Some media in my seq played OK. The entire seq plays perfectly in CS6.
    Also I noticed the BM resolution settings seem to be gone in the view settings. Is that moved somewhere?
    Robert Brown
    Editor/VFX/Colorist – FCP, Smoke, Quantel Pablo, After Effects, 3DS MAX, Premiere Pro
    https://vimeo.com/user3987510/videos
  • Robert Brown
    Yes there is.
    Robert Brown
  • Robert Brown
    June 22, 2013 at 2:15 am
    Just an update, if I use a Canon XF seq it seems to work OK. If I use my custom ProRes seq, the BM seq, or AVCHD, I get the strobing. I have check the transmit setting and it is on.
    And also the video that strobes is from a multi cam seq. If I turn on the multi cam mode in the record monitor, it does not strobe. It is a simple 2 cam seq.
    Robert Brown
Page 2 of 2
