Activity Forums Apple Final Cut Pro Legacy external monitor unresponsive in FCP
  • external monitor unresponsive in FCP
    Posted by Chrisusvi on May 23, 2005 at 3:28 pm
    My external monitor isn’t playing what is playing in the Canvas window in FCP.
    When I put the CTI anywhere in the timeline it DOES change in the external monitor to that point (as a frozen image). It just doesn’t want to play the video at normal speed in the external monitor.
    I checked the ‘ALL FRAMES’ option in the VIEW>EXT. VIDEO menu. It had seemed like it had been less responsive within the last few months. Now it seems as if it has come to a stand-still.
    Any suggestions?
    Matt Sandström replied 21 years, 3 months ago 4 Members · 4 Replies
  • Rob Forsythe
    May 23, 2005 at 4:18 pm
    This list contains about everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire
    b. Viewing in the Canvas window on the computer screen
    c. Being able to record on the external FW DV deck or camcorder..
    Try things in this order until you find the “cure”:
    1. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    2. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    3. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    4. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    5. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    6. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    7. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    8. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    9. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    10. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    11. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    12. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    13. Important: Quit FCP, then Restart FCP.
    14. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
  • Josephine Healey
    May 23, 2005 at 7:28 pm
    Please describe your setup. Including OS and FCP version, even if one of the above listed things helps, so the rest of us will know for future reference. Thanks!
  • Chrisusvi
    May 23, 2005 at 9:02 pm
    I fixed the problem with the external monitor.
    Thanks.
  • Matt Sandström
    May 23, 2005 at 9:18 pm
    ok, how?!?
    /matt
    https://www.mattias.nu/
