Activity › Forums › Adobe Premiere Pro › External monitor SDI in Premiere Pro on PC
  • External monitor SDI in Premiere Pro on PC
    Posted by Hrabba Gunnarsdottir on April 6, 2017 at 5:34 pm
    I am trying to get signal to an external monitor with Premiere Pro on a PC platform. I have an HDMI to SDI Blackmagic converter and several output options including thunderbolt or HDMI output or computer monitor output (looks like HDMI) I am not getting anywhere with this. In old days with Final Cut 7 I had a Kona Card which I had to configure correctly but I am not seeing any such options on my PC? Help anybody?
    Tero Ahlfors replied 9 years, 5 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    April 6, 2017 at 5:51 pm
    The converter is just a converter. You will need something that can output the signal like a Blackmagic Mini Monitor. You can also use the outputs of your computer. There should be settings under Preferences – Playback.
  • Hrabba Gunnarsdottir
    April 6, 2017 at 6:10 pm
    Thank you for your response . It does not seem to recognize the black magic converter. Do I have to download anything for the computer to see it?
    thanks again
    Hrabba
  • Andy Patterson
    April 6, 2017 at 7:52 pm
    The Kona is a video capture card designed for real-time playback to broadcast equipment when using FCP, Avid, Premiere etc. If you are trying to take the HDMI out from the computers graphics card the HDMI to SDI converter may only work with broadcast compliant formats.
  • Tero Ahlfors
    April 7, 2017 at 4:05 am
    [Hrabba Gunnarsdottir] “It does not seem to recognize the black magic converter. “
    The converter is not an I/O device. It just converts a signal to another interface. If you need SDI you need to:
    -Get an I/O device that has SDI out.
    Or:
    -Insert an HDMI cable to your GPU, run that through the converter and connect the SDI to your monitor. Then enable it in the playback settings. If I remember correctly it was called “fullscreen preview” or something. Note that the monitor is probably expecting some sort of a standard signal so your sequence needs to match that.
