Activity › Forums › Apple Final Cut Pro Legacy › External Monitor Not smooth
Posted by Greg Ball on December 27, 2006 at 7:08 pmI have my FCP system hooked up to an external composite monitor. The image seems to have a slight strobe to it. It actually looks better in the canvas window. Is there some setting that I need to use to get it to look right for clients in my composite monitor?
I’m on FCP studio, on a Mac G5 quad, 4 GB RAM, using an AJA card from Beta SP. Thanks
Greg Ball replied 19 years, 9 months ago 5 Members · 6 Replies -
Chris Poisson
December 27, 2006 at 8:30 pmGreg,
What kind of monitor? How is it connected? If it looks worse than the canvas something’s wrong. The canvas is low rez.
Bouncing Account needs new email address
December 27, 2006 at 9:10 pm[Greg] “tor. The image seems to have a slight strobe to it.”
When the timeline is stopped, the image will “dance” (jitter) if you have stopped on a frame with some motion in it, because the the video interlace.
Is that what you mean by “strobe”?
David Roth weiss
December 27, 2006 at 9:34 pmGreg,
A composite video signal is the lowest quality video signal there is, prone to dot crawl, judder, and a host of other anomalies. You have an AJA card and a Beta deck, so you should be able to loop a component signal through to a monitor. If your monitor has no component signal, you really must replace it if you ever want a client monitor to display a realistic and satisfactory representaion of your work.
DRW
Rafael Amador
December 28, 2006 at 1:46 pmTo me that sounds like a field-domminance problem. If you are setting upper-first footage in a lower-first time-line, or the opposite, FC try to correct the difference in the field-domminance aplying a shift-fields filter to the clips in the time-line. The problem is that your KONA try to do the same so the fields order is chaged twice, and the result is wrong order. At least its happens like that with the Blackmagic cards. The solution (if is this the problem) is to uncheck the shift-field filter in the clips and the videocard will do it OK.
salud,
rafael -
Greg Ball
December 28, 2006 at 7:28 pm(rafalaos) The solution (if is this the problem) is to uncheck the shift-field filter in the clips and the videocard will do it OK.
Where would I find this to uncheck it? How can I see if this is indeed the problem? It must be something in Final Cut as I also edit on Media 100 on this system with no problems like this.
Greg Ball
December 28, 2006 at 8:31 pmThe playback frame rate on the timeline was set to half. Changed it to dynamic and the problem was fixed. Thanks guys!
