Activity Forums Apple Final Cut Pro Legacy External Monitor no Video Playback?
  • External Monitor no Video Playback?
    Posted by Andrey Karpov on November 11, 2011 at 4:39 am
    Hey I’ve just purchased an external monitor to use while editing.
    Now I’ve got the monitor hooked up via HDMI to my EVGA GTX480 and I have the image on both screens. Basically everything works.
    Except when I turn the external monitoring on, there is no video playback on either screen. Just a still frame.
    If I play and then pause the image on both monitors updates to the new point. But the video simply will not play. (audio however does)
    It’s definitely not due to system performance.
    So I’m guessing it’s just some setting I probably messed up.
    Any advice?
    Andrey Karpov replied 14 years, 10 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    November 11, 2011 at 2:34 pm
    My guess is that your graphics card’s HDMI out isn’t supported in FCP… You really need a proper video I/O to do this correctly. Something from AJA, BlackMagic or Matrox would do the trick.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Andrey Karpov
    November 12, 2011 at 12:34 am
    Thanks for the quick response. But due to the still frames of video being displayed when the video pauses I believe it’s possible for me to play back the video.
    Perhaps I may be overlooking some settings.
    What would the proper preferences be for such a connection?
