Activity Forums Adobe Premiere Pro External monitor no longer appears in realtime playback external device drop down menu
  • External monitor no longer appears in realtime playback external device drop down menu
    Posted by David Cabestany on September 29, 2011 at 11:02 pm
    I have an external HP monitor (1920×1080) connected to my iMac that I use as an external monitor for playback.
    I normally preview the program monitor in it without any trouble, but today, for some reason it no longer appears as an option, please see attached.
    Anyone can tell me what I did wrong and how to get back my monitor to the list?
    Thanks in advance.
    Ryan Constantino replied 12 years, 6 months ago 4 Members · 6 Replies
  • Jon Barrie
    September 29, 2011 at 11:28 pm
    1. Did you perhaps alter the resolution after launching PPro?
    2. Are you seeing a little Yellow Hazard Icon in the bottom right, it may give you a message related to the situation (and others)
    3. Could you perhaps have disconnected or stopped the Extend Display option and had it set to duplicate or off for a moment?
    Usually a restart gets things back on track, just make sure the monitor is in Extend mode and not Duplicate and the connection is solid.
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • David Cabestany
    September 29, 2011 at 11:46 pm
    Hi Jon,
    1. No, I didn’t. I also restarted my computer to check for this and have a fresh launch of Premiere Pro.
    2. I did see the yellow hazard icon and the message was related to a resolution change on the monitor, so it advised to restart PPro to avoid any issues, I did that and the issue remained.
    3. Nope, I haven’t unplugged it and the connection is stable, I can use it with other software and it works as expected, is not mirroring.
    The only modification I did in the past few days is attach a third monitor, which required a driver to work, due to the fact that it is connected via USB, not the usual mini port/Thunderbolt port on my iMac. I tried getting the external monitor to be detected with the third one both attached and not, but without success.
    Thanks.
  • Jon Barrie
    September 29, 2011 at 11:57 pm
    Hi David,
    Any changes are worth being aware of, especially if it involves the display side of your setup. I’d say something happened in there. iMac’s really arent designed for the multi-screen setup outside of the two (iMac +1 external).
    Let’s try going backwards one step at a time… 🙂
    – Either uninstall the driver you tried for the 3rd (USB connected) monitor or reinstall the driver for the iMac.
    – Time machine would be great here if that has a step back for the driver install.
    See how we go here, try to run PPro without the external monitor attached at all. Then shut down system. Reconnect the Monitor, get the extended setting working, relaunch PPro.
    Let me know (Lmk) – JB
    Jon Barrie
  • David Cabestany
    September 30, 2011 at 1:22 am
    Thanks Jon, look like I’ll have to do just that. I’ll post the results as soon as I do it.
    Best,
    D.
  • Ian Northrop
    January 5, 2012 at 1:37 am
    I was having a similar issue – plasma tv as ‘Realtime Playback’ monitor just stopped working suddenly. My problem ended up being that my Premiere Pro window was creeping over to the other monitor (I have them set-up side-by-side, not mirrored). This was enough to disable ‘Realtime Playback’ on my system. Sometimes the solutions are far simpler than we conjure-up in our minds..
  • Ryan Constantino
    February 23, 2014 at 4:17 am
    I actually had to create an account just to reply to you. Thanks for posting this. I’m astounded how simple of a solution this was. Thanks for posting. Worked for me.
