Activity Forums Apple Final Cut Pro Legacy External Monitor audio sync
  • External Monitor audio sync
    Posted by Bob Root on January 26, 2009 at 4:06 pm
    Hi all,
    Running FCP 6 on a MacPro 8-core 2.8gHz. Media files are on an external Burly SATA tower.
    I recently hooked an NTSC monitor up to my Black Magic card via SDI.
    Audio through my NTSC monitor speaker is in perfect sync. While this is encouraging, I really want to monitor FCP audio through my external speakers.
    The problem I am having is that when I switch my Audio Playback in the Audio/Video settings to my external speakers, sync gets thrown way out (both on the NTSC and my computer monitor).
    I’m not at my system right now, but will be happy to provide any additional details if needed.
    Bob
    Bob Root replied 17 years, 7 months ago 4 Members · 4 Replies
  • Russell Lasson
    January 26, 2009 at 4:21 pm
    I would highly suggest connecting your speakers to the audio output of your decklink card (if you have analog audio out on that card).
    -Russ
    Russell Lasson
    Ridgeline Digital Cinema Mastering
    Universal Post
    Salt Lake City, UT
  • Arnie Schlissel
    January 26, 2009 at 6:40 pm
    Three words: Audio Follows Video.
    As Russell says, you need to connect your speakers to your decklink card. Preferable via some sort of mixer. Both Behringer & Mackie make good low end mixers, if there’s a Guitar Center near you they should have something in stock.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Parke Gregg
    January 26, 2009 at 8:40 pm
    If a Decklink is like a Kona 3 card, you may only have AES audio coming out. I had this problem and purchased a Behringer Ultramatch Pro AES to analog convertor. This works great and I highly recommend it. Kona’s AES to the Ultramatch, from that I get balanced analog to my mixer that controls the audio monitors. This is also perfect for recording to an analog deck.
    -Parke
    ——-Stuck On On——–
    Audio and Video Post Production
  • Bob Root
    January 26, 2009 at 10:36 pm
    Thanks for all of the helpful responses.
    Looks like some additional gear is on my horizon… just when I thought I was at the end of my spending spree.
    Can anyone expound on why the sync would be so far out? I’m seeing anywhere from 8 to 30 frames sync difference (upon relaunching FCP) between audio and video. There doesn’t seem to be any consistency in sync loss.
    Thanks again,
    Bob
