Activity Forums Apple Final Cut Pro Legacy External monitor
  • External monitor
    Posted by L Dee johnson on January 8, 2008 at 7:46 pm
    HI,
    I’m working with a MacBook Pro and FCP 5.
    I want to do a remote edit at a clients office.
    I am tryhing to hook up an external moitor through the external video adapter on the side of my MacBook.
    I get a view of the desktop but cannot get it to to display the canvas view only.
    I have tried switching the eternal view under VIEW from none to All frames , turned everything on and off, but no success. I still just get the desktop displayed on the external monitor. Tried the Refresh A/V devices. Under Audio/Video settings i have tried mirroring on and and off, the setup is Apple Firewire NTSC (720×480).
    If I go to Digital Cinema dekstop preview, i get full screen on the external, but also on the MacBook. I want to be able to edit on the mac and show the video on the external.
    Any suggestions?
    Thanks in advance.
    David Peralta replied 18 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    January 8, 2008 at 8:27 pm
    Go to System Preferences and in Displays switch off mirroring.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • L Dee johnson
    January 8, 2008 at 8:54 pm
    Hi Tom,
    When I do this, I get a Mac screen on the external display, but still now video display on external. It just stays on the mac screen. Not the destop, but the standard mac blue background. I have made sure under View, External Video, All Frames. Still no success in getting playback to the external.
    Suggestions please and thank you!
  • L Dee johnson
    January 8, 2008 at 10:40 pm
    Clarification on my last post. When I turned mirroring off in the System preferences, as Tom suggested, now I get a dual monitor setup as if I was doing a dual monitor edit. The cursor will go from screen to screen.
    I need just video playback out to the external monitor.
    Any ideas?
    Thank you.
  • Dunwoody Lampton
    January 9, 2008 at 1:32 am
    Did you try:
    VIEW > VIDEO OUT > REFRESH VIDEO DEVICES or TOGGLE LAST
    Sometimes choosing one or both of these options a few times engages the monitor, essentially refreshing the connection, especially on first-time power-up.
  • L Dee johnson
    January 9, 2008 at 1:43 am
    HI,
    I have found that I was capturing in FCP5, Easy Set-up DV_NTSC 24P(23.98) Advanced pulldown.
    This setting does not allow the use of the external monitor.
    I tried switching to DV-NTSC on the Easy set up and the external works fine.
    So the question is what ‘Easy’ setting should I use tp capture footage that was shot with a DVX 100 24 PA setting. The program will be viewed from a DVD to either a plasma or LCD screen. I want it to look it’s finest.
    So do you ingest the footage in one setting in FCP 5 and then switch to DV NTSC for the edit, so the you and the client can view the footage on the external monitor?
    Your thoughts?
    Thank you!
  • Dunwoody Lampton
    January 9, 2008 at 2:08 am
    First, Tom W. or one of the other veterans are more experienced and qualified than I am to answer your concerns.
    I’ve never worked with your camera or with 24P before, so anything I tell you is just a guess.
    But in my experience with other formats, it’s been irrelevant to watch my NTSC monitor during capture, since the FCP interface/capture window on the computer monitor always took precedence in the capture chain over any external monitor.
    I would think that, once you’ve ingested successfully, returning to DV-NTSC shouldn’t have any negative effect on your editing process, since that setting should be purely monitorial.
  • David Peralta
    January 10, 2008 at 2:45 am
    Why not just preview out of the camera? since your using firewire anyway to capture, just take the output of your camera and hook that to an NTSC monitor.
    hmm… I wonder what this button does…
