Activity Forums DaVinci Resolve external mattes
  • external mattes
    Posted by Sean Sartori on January 10, 2012 at 5:20 pm
    I am having a problem getting an external matte to load. I have a simple composite, with a background plate, a foreground plate, and a matte rendered as pro res HQ. Its a simple shape that moves across the screen, keying in an element of the foreground plate. Am I correct to assume that I can do this in Resolve? I’ve read and reread the manual section on external mattes, and it seems I should be able to do this, and be able to grade both video layers and do the composite in Resolve, rather than it being done in AE.
    I follow the directions, and highlight the foreground clip in the media pool, then select the matte and select “add as matte” . Nothing happens. the matte is not loaded.
    Is there a spec on the format of the matte? Mine is Pro Res, 1920×1080, same size and codec of the rest of the piece.
    any help appreciated!
    Sean Sartori replied 14 years, 8 months ago 2 Members · 2 Replies
  • Toby Tomkins
    January 10, 2012 at 6:39 pm
    Check that the durations of the clip and matte are exactly the same.
  • Sean Sartori
    January 10, 2012 at 10:28 pm
    that was it!!
    thanks. that was driving me crazy.
