Activity › Forums › Adobe Premiere Pro › external hard drive for cineform hd avi files
  • external hard drive for cineform hd avi files
    Posted by Scott Jensen on September 10, 2007 at 8:29 pm
    Can someone give some input on external hard drives. I need one fast enough (Cineform specifies 7200rpm) to edit Cineform Aspect HD files. I believe these files are around 100Mbps?
    I’d like one thats usb powered, 200gb or higher and able to handle the data rate.
    Thanks.
    Tim Kolb replied 19 years ago 4 Members · 3 Replies
  • Aanarav Sareen
    September 10, 2007 at 10:47 pm
    I doubt that you are going to find that fast a drive, especially one that is USB powered.
    Take a look at the Western Digital “MyBook” drives. They are not USB powered, but they certainly do the job for me.
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Vince Becquiot
    September 10, 2007 at 11:07 pm
    I would recommend the Free Agent eSata II drives by Seagate (750 Gigs should give you some room to do some uncompressed work). The speed is pretty amazing.
    You will also need a eSata II card adapter and a Sata cable.
    I think that’s the only way to go here for HD.
    The eSATA II card will be cheaper on a PC than a Laptop, count around $50.00 for PC, and $80.00 for Laptop.
    The whole thing should cost you around $400.00 at NewEgg.com.
    Cheers,
    Vince
  • Tim Kolb
    September 11, 2007 at 1:22 pm
    [Scott Jensen] “Can someone give some input on external hard drives. I need one fast enough (Cineform specifies 7200rpm) to edit Cineform Aspect HD files. I believe these files are around 100Mbps?”
    When I used Aspect on projects (I use Prospect on my laptop now for compatibility with my workstation), I was having no problem getting two streams from a typical 7200rpm drive via FW. FW A has a datarate ceiling of 400 Mb/s and USB2 has a datarate ceiling of 480 Mb/s, but if pushed, FireWire can be a bit better in that it seems USB2 can have more fluctuation between peak and sustained data rate.
    A bus-powered drive or battery powered drive fast enough for editing, if it exists in any practical form, would chew through battery power (bus-powered would drain the laptop battery) one way or the other.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
