External Hard drive crash – Contains FCPX library in it
My 2TB external hard drive had my fcpX library and I was editing my film on the hard drive. When I connected my hard drive today, a window popped up asking if the hard drive should be ejected or initialized since it is not readable. Thankfully I know that initializing a hard drive means formatting it and so I ejected it. I tried in multiple systems (windows and apple) and tried with different firewires, with the same response. The hard drive has gone in for recovery now and the scanning is in progress. I am concerned about the fcpx library. If recoverable, will it be recovered as one file or will be renamed and/or recovered individually as separate folders, in which case I have lost my edit since re-linking all the files will be impossible. Bit of a situation because the library was about 1.2 TB in size and I guess I over-worked my hard drive and realized it bit too late, unfortunately. Having edited one film completely on a hard drive I assumed there was no issue in doing so but now that my hard drive crashed and I read more for a solution, I realize that it was a risky move to make. Can someone please give me a glimmer of hope????????????????????????????????????????????
