Activity Forums Maxon Cinema 4D External Composting Tag AEC file. Timings all wrong
  • External Composting Tag AEC file. Timings all wrong
    Posted by Chris Behl on December 22, 2016 at 11:03 am
    Hi
    So I have a c4d R17 project rendered out at 25 fps. The animation was too slow.
    So I went to animation view. Then….
    Function-Move/scale.
    I added scale of 2 to the timeline and to some other areas 1.4
    This was to overall speed up all the keyframes.
    Perfect. Animation looks a lot better now.
    However when I import my aec file (freshly saved out) the timings are still for the original time line. So the times are off for all my solids.
    How do I solve this?
    OK I SOLVED IT.
    I HAD MANUAL FRAME RATE SET AND IT WAS NOT CORRECT.
    PRETTY OBVIOUS MISTAKE
    THANKS
    Chris Behl replied 9 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
