Activity › Forums › Maxon Cinema 4D › External composition tag’s layer is inverted in After Effects
  • External composition tag’s layer is inverted in After Effects
    Posted by Jeremy Paul on August 7, 2017 at 5:15 pm
    I am using External compositing tag to transfer Position, rotation properties of a layer into AE. When I apply a texture to this object in Cinema, it is correctly orientated.
    If I use External compositing tag layer in AE (I actually copy keyframes from the imported layer and paste it to the image I want), the image is inverted so I need to adjust y-scale. Why is that and how can I fix it?
    The position and rotation is correct, only the y scale needs to be multiplied by -1. Can this step be eliminated in Cinema or is this an after effects issue. I’ve got a feeling that this has something to do with how axis are orientated in Cinema and AE.
    Jeremy Paul replied 9 years, 1 month ago 2 Members · 2 Replies
  • Steve Bentley
    August 7, 2017 at 9:55 pm
    I’m not sure who the culprit is but there is no “United Nations of Y is up” kind of thing. Plexus is like this too, one of the first things you do is invert the Y.
    At least its as easy as a negative sign, packages like formZ consider Z up.
    It also has to do with the fact that AE has it’s origin at top left so when you increase the y value you travel down the composition window not up as positive values do in cinema.
  • Jeremy Paul
    August 9, 2017 at 8:05 am
    Thanks for help! For those who will face similar issues. Go to Tools->Modes->Enable Axis and hit R to rotate it.
